Updated to 2.0.0.3357 and now will not start
Running sonarr on an asus router for a past few months. Usually the updates are smooth but for some reason since this update, sonarr wont start.
The log file shows this error:
[Info] Bootstrap: Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.3357
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone.Console
[Info] MigrationLogger: *** Migrating data source=/root/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
System.Data.SQLite.SQLiteException: unable to open database file
at System.Data.SQLite.SQLite3.Prepare (System.Data.SQLite.SQLiteConnection cnn, System.String strSql, System.Data.SQLite.SQLiteStatement previous, UInt32 timeoutMS, System.String& strRemain) [0x00000] in :0
at System.Data.SQLite.SQLiteCommand.BuildNextCommand () [0x00000] in :0
Not sure why it is saying it is unable to open the db file as the file /root/.config/NzbDrone/nzbdrone.db exists.
I tried restoring the config and db from various backups but it still gives the same error at startup.
Any tips?
Which version of mono is it running?
Try deleting nzbdrone.db as well as the nzbdrone.db-shm and nzbdrone.db-wal files as they could mess up the DB on start up.
Is Sonarr running as root? Not permissions related?
Hi Markus,
It’s mono v4.0
It’s fixed now. Here is the solution in case anyone else has a simial issue.
rename /root/.config/NzbDrone to /root/.config/NzbDrone-bak
Start sonarr, it should start ok and create a new /root/.config/NzbDrone folder with defaults
Stop sonarr and copy in the following from the original /root/.config/NzbDrone-bak to the new /root/.config/NzbDrone
nzbdrone.db
config.xml
MediaCover
Now start sonarr again and all should be okay
