hi there.
I have the same problem.
Juist made the switch to Sonarr… getting lots of dupes… also some quality upgrades beyond what i want.
ask for 720 get 720 then 1080…
profiles are just standard from install.
Happy to provide any logs etc.
I use SAB api…
Please start a new thread next time your post had no relation to the issue in the previous thread as you’re using SAB and not the blackhole method.
Please post a screen shot of your Quality profile and explain your issue further, with a concrete example.
Unwanted Quality Upgrade
Duplicate episodes downloaded back to back
I have only one indexer listed. using sab with api access. catagory tv for both sonarr and sab. the episodes are being managed correctly. Just getting the above result with dupes and the occasional over quality
Both those duplicates show in Sonarr’s history?
Please hastebin debug logs of Sonarr queuing these releases so we can see why it did so.
If you click on the i
icon, why does it say it was deleted?
File was deleted to import an upgrade
It only seems to have snatched it once.
FYI
im using the synocommunity package
Since Sonarr only grabbed the episode once it sounds like SB or SR is still running or an indexer is pushing NZBs to SAB.
and there you have it. I have a service restart scheduled once a day.
Ive changed SB user to undefined. It definitely wont start now. No doubt this will clear things up
Im a moron… Sorry
Thanks for your time
markus101
Closed
December 11, 2015, 1:07am
10
