Unselected quality grabbed
Interesting issue today. I have From Dusk Til Dawn set to grab at 720p, and stop at 720p. The only available options appear to be a 720 WEB-DL, and Drone went ahead and grabbed it anyway :slight_smile: Interesting that the manual search shows the exclamation mark, so at least in that instance Drone knows it’s not a suitable file.
I’ve grabbed the log file, but it wasn’t set to debug or trace as I’ve only just noticed what happened. Here’s the relevant bit (I added the Fargo part just because I do have that set to WEB-DL on purpose and it grabbed them both around the same time. Just in case it’s related):
14-4-30 19:30:02.8|Info|Sabnzbd|Adding report [From.Dusk.Till.Dawn.The.Series.S01E07.720p.WEB-DL.DD5.1.H.264-BS] to the queue. 14-4-30 19:30:05.3|Info|DownloadService|Report sent to download client. From.Dusk.Till.Dawn.The.Series.S01E07.720p.WEB-DL.DD5.1.H.264-BS 14-4-30 19:30:07.3|Info|Sabnzbd|Adding report [Fargo.S01E03.720p.WEB-DL.DD5.1.H.264-BS] to the queue. 14-4-30 19:30:09.3|Info|DownloadService|Report sent to download client. Fargo.S01E03.720p.WEB-DL.DD5.1.H.264-BS
14-4-30 21:27:07.5|Info|NzbSearchService|Searching 3 indexers for [From Dusk Till Dawn : S01E07] 14-4-30 21:27:07.5|Info|FetchFeedService|Finished searching Wombles for [From Dusk Till Dawn : S01E07]. Found 0 14-4-30 21:27:08.7|Info|FetchFeedService|Finished searching Dognzb.cr for [From Dusk Till Dawn : S01E07]. Found 1 14-4-30 21:27:09.4|Info|FetchFeedService|Finished searching Nzb.su for [From Dusk Till Dawn : S01E07]. Found 1 14-4-30 21:27:09.4|Info|DownloadDecisionMaker|Processing 2 reports 14-4-30 21:32:44.4|Info|NzbSearchService|Searching 3 indexers for [From Dusk Till Dawn : S01E07] 14-4-30 21:32:44.4|Info|FetchFeedService|Finished searching Wombles for [From Dusk Till Dawn : S01E07]. Found 0 14-4-30 21:32:45.7|Info|FetchFeedService|Finished searching Dognzb.cr for [From Dusk Till Dawn : S01E07]. Found 1 14-4-30 21:32:46.2|Info|FetchFeedService|Finished searching Nzb.su for [From Dusk Till Dawn : S01E07]. Found 1
Your quality profile includes, HDTV-720p, WEBDL-720p and Bluray-720p with the cutoff at HDTV-720p, unless you already had it in HDTV-720p (which wasn’t available), drone would grab WEBDL-720p.
For the manual search its showing an exclamation mark because you already have the file at that quality (the exclamation mark is a tooltip that tells you why it was rejected).
More information on how quality profiles work:
@markus101 said:
Your quality profile includes, HDTV-720p, WEBDL-720p and Bluray-720p with the cutoff at HDTV-720p, unless you >already had it in HDTV-720p (which wasn’t available), drone would grab WEBDL-720p.
Right, I had it in my head that it would only grab the lowest quality I’d selected, especially as I had that set as the cutoff. Hmm, I’m going to have to rethink some things if that’s how it works.
Thanks markus.
