Unraid 6 - A few questions
Hello, I recently set this up successfully in a 64 bit install Unraid 6 as a plugin. Seems all is working well using mono 3.2.8. I notice in the log that i get a reoccurring message:
“Mono - Starting mono --version”
It happens almost every 5 minutes. Is this normal and if so, does it need to happen so often?
Thats currently when health checks are triggered, the current implementation was a get it working solution, eventually we’ll make it do it on start up only.
There is no harm in it running as frequently as it does, just a logging message.
ok, I figured that, it was filling my log file so I wasn’t sure if it was somehow triggering more often that it was supposed to.
