"Unknown Method" when adding to Deluge from kat.cr
OS: Windows
Adding any file from kat.cr (kickass indexer) gives an “Unknown method” error.
NzbDrone.Core.Download.Clients.DownloadClientAuthenticationException: Unknown method
   at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.ProcessRequest[TResult](DelugeSettings settings, String action, Object[] arguments) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 198
   at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.SetLabel(String hash, String label, DelugeSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 157
   at NzbDrone.Core.Download.Clients.Deluge.Deluge.AddFromMagnetLink(RemoteEpisode remoteEpisode, String hash, String magnetLink) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\Deluge.cs:line 40
   at NzbDrone.Core.Download.TorrentClientBase`1.DownloadFromMagnetUrl(RemoteEpisode remoteEpisode, String magnetUrl) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TorrentClientBase.cs:line 176
   at NzbDrone.Core.Download.TorrentClientBase`1.Download(RemoteEpisode remoteEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TorrentClientBase.cs:line 75
   at NzbDrone.Core.Download.DownloadService.DownloadReport(RemoteEpisode remoteEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\DownloadService.cs:line 66
   at NzbDrone.Api.Indexers.ReleaseModule.DownloadRelease(ReleaseResource release) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Indexers\ReleaseModule.cs:line 67
   at NzbDrone.Api.Indexers.ReleaseModule.<.ctor>b__0(Object x) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Indexers\ReleaseModule.cs:line 46
   at CallSite.Target(Closure , CallSite , Func`2 , Object )
   at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
Which Deluge version and do you actually have the label plugin enabled?
It was the label plugin, thanks for the help
