Having an issue with Sonarr getting stuck with the torrent download percent from my rtorrent seedbox and never finishing randomly, even though the file has completed in rtorrent/rutorrent client and already downloaded to the sync folder for Sonarr to pickup.
Tasks are never going to run if you’re running into that error in your logs, but not sure how Sonarr is failing with that error because the TypeName is used to determine if the task already exists and it’s only added if it doesn’t.
You could try using a SQLite editor to clean out the existing tasks. DELETE FROM ScheduledTasks
