Hello everyone,
I’m currently just finished building my second Plex Server and thought I’d give Sonarr a shot after hearing so many good things about it. Definitely refreshing change after coming from Sickbeard. So far Sonarr works beautifully, however I’m unable to access the web interface on different machines.
Admittedly I didn’t read the install instructions prior to installation, goofed up by not running as administrator. By doing further reading, it sounded like I can stop the service and run as administrator once and restart, which should fix the problem. However it’s still not working. I even went as far as uninstalling everything, and reinstalling… but still no go.
Running Win 8.1, ports are open and I even tried turning firewall off entirely.
Any help would be great! Thanks!
EDIT: Ok, I think I found the solution. Diving into the firewall settings, I had to manually set “NZBDrone” to “Public”.
