Unable To Post Process Random String Episode Names
So NZBDRONE is having issues processing my Drone Factory folder. I took a look at the file names and they are WONKY…I’m guessing the filenames are weird to escape DCMA but nzbdrone can’t process it. Example being Weeds.S01E10.DVDRip.XviD-NZBgeek shows up as AHFMZXGHEWD660. Any thoughts?
Its a known issue: https://trello.com/c/PHR3ztK1/616-importing-hashed-releases
Are the files in folders?
They are definitely in folders and the folders have the correct series and episode information.
+1, this is becoming an increasingly common problem. If I manually copy the name of the folder, then paste it onto the the filename within the folder, nzbdrone will then process it correctly.
That it is. I have a good amount of episodes sitting in my drone directory waiting to be processed. Markus, can you guys add an advanced setting in the develop branch that allows us to use folder name rather then file name?
We plan to support using the folder name, but its not something that will be optional, forcing through a solution is not the right approach, but it is being worked on among some other import improvements.
Cool cool thanks bud.
