Unable to keep Sonarr running
Sonarr version (exact version): latest
OS: Mac OS 10.12.3
((Debug logs)): 17-2-27 15:11:47.7|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
Description of issue: every time I start up Sonarr I get the listed error, any idea how to fix it? I can give more info if needed.
Is another instance running or is something else running on that port? Check Activity Monitor and stop any instances running then start Sonarr up again.
