Sonarr version (exact version): 2.0.0.5322 Mono version (if Sonarr is not running on Windows): OS: Debug logs: Description of issue: Unable to connect to SABnzbd
I switched IP in the settings and ensured the API key is correct. I have no problems connecting from couchpotato to SABnzbd after switching IP.
Currently running Sonarr, SABnzbd and Couchpotato in Docker.
Downloads are now being sent to SABnzbd but just stay in the downloads folder and are not being filed by Sonarr. I’m still seeing the same errors as per my first post: All download clients are unavailable due to failures
Restarting and even trying to create a new download client doesn’t help, still throws same error…
It’s now sending unlimited download requests for my shows most likely due to the connection errors so I have to pause everything and manually manage this…does anyone have an idea here what’s going on here according to the logs I shared?
Had to disable SSL on Sabnzbd and connect over HTTP from Sonarr to get it working again…even renewed the CA root so not sure why all of a sudden it would start refusing SSL connections? …
