Sonarr version 2.0.0.4990: Mono version (if Sonarr is not running on Windows): OS: Windows 10 Pro ((Debug logs)): https://hastebin.com/azatapojuv.tex (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
Hey,
It’s the first time I’m trying to use Sonarr. Installed latest version of Sonarr, Deluge and Jackett. Configured them by following a guide.
When I try to add an Indexer I get the error “Unable to connect to indexer, check the log for more details”. It’s in the debug logs.
I’ve tried adding Nyaa preset and I tried adding Kickass, Rarbg etc… from Jackett as well. They all give me the same error.
Except this last time that I tried again before writing this post, I get this error when I try to use Torznab: “No results were returned from your indexer, please check your settings”, also included in the log.
I did a fresh install.
I port forwarded all the ports used in all 3 apps. (and tried new ports as well)
Updated to develop branch of Sonarr.
Checked to make sure no proxy is enable on my OS with a cmd command one of the admins had posted on another thread. No proxies.
Wow, I spent so much time yesterday trying to fix this! You just made my day! ^^
I changed my dns servers to google’s 8.8.8.8 and 8.8.4.4 and it instantly worked!
Thanks!
Hmm… I discovered something new. I still get the “No results were returned from your indexer” error if I add more than 1 category.
I entered exactly 5070,5040 for Kickass and I got the error. But 5070 or 5040 alone result in success.
I also returned to my original dns and I got similar results. Success with one catergory but error with more than one.
