Mono version (if Sonarr is not running on Windows):6.4.0
OS: Unraid
Debug logs: https://pastebin.com/Y0JHuRQU
Description of issue: Snowpiercer episodes in Ultra-HD are not being downloaded and not showing in the Manual Search, stays red in the Calendar
Have you selected the correct categories for your indexers in Sonarr? Most indexers put UHD content in a category Sonarr won’t check by default.
there are 5030,5040
I would assume 5050 is the UHD but exactly where do I find those codes?
Go to the UHD page on your indexer, usually the category code is in the url.
you mean in Jackett, got ya!
