I am running headless server in remote location, so running in console isn’t ideal for me and would like to set up auto start.
I’ve followed auto-start methods written below
I am a linux newbie so I think I am missing some important step that is causing the issue.
The upstart method seems fairly easy but I get error when I try to start sonarr.
error message with something regards to upstart connection.
Can anyone help me set-up auto start?
I’ve been having the same problem after the update. Seems ubuntu switched to systemd instead of upstart.
put the following in /etc/systemd/system/sonnar.service
[Unit]
Description=Sonarr Daemon
After=network.target
[Service]
User=[username]
Restart=always
RestartSec=5
Type=simple
ExecStart=/usr/bin/mono --debug /opt/NzbDrone/NzbDrone.exe
TimeoutStopSec=20
[Install]
WantedBy=multi-user.target
then a simple
sudo systemctl start sonarr
I’ve got it to work by installing upstart-sysv.
Is there a benefit for me to switch to service?
It says I have no root access to this folder? How do I fix this (complete Linux n00b right here)
