OS:
i unmonitoed all the episodes and manually check for anything less than 40 days old as anything older than that seems to be the other “the fix” show
you can open the episode history and flag the downloads that end up being for the other show as failed and it should go off and try again, you just have to keep repeating that until it cant find anything and then it should only pick up new stuff
so long as someone doesnt re-upload an ep from the other show it should be fine
both shows also have two versions in tvdb which seems strange considering how anal and narky they get about their data
Thanks. I’ve had two shows with the same name in the past without this problem so not sure why it’s like this with this show.
