When setting up the Twitter connect with consumer key, secret, access token and secret you get a prompt:
Using Direct Messaging is recommended, or use a private account.
The same procedure works in Radarr with no errors.
Logs
I can provide as necessary.
System Information
- Sonarr Version: 2.0.0.5344 - Mar 13 2020
- Operating System: macOS
- Mono: 5.18.0.240
I had twitter working just fine but then Twitter banned my account so I had to switch to a new one with new API info. Radarr worked just fine, Sonarr is complaining.
