TV Show - Offspring - Not Found
Added the show “Offspring” for the wife, but NZBDrone never finds new episodes. I use OZnzb as the indexer, and all the files are there, but even with a manual search NZBDrone doesn’t detect them. Only thing I noticed was that the episode quality is PDTV on OZnzb, not sure if that makes a difference.
Edit: Just noticed after I added them all the SAB manually that NZBDrone has changed there status to downloading, so it recognises them as the correct episodes once they are downloading, but can’t find them from my indexer.
Oznzb doesn’t have the tvrage ID attached to the episodes for Offspring, they will need to add them for searching to succeed.
Multiple indexers are a REALLY good idea, for this, and other reasons - aka ‘shit happens’.
I also have the show, did a search for an episode and the following indexers returned results;
Dognzb.cr
Nzb.su
Nzbs.org
oznzb didn’t return anything :frowning:
