Just saw downloaded S01E05 of Forever (2014) but … this ep is aired in 6 days. it seems that E05 = E04
but I’ve no clue what happened is this an issue of incorrect uploading within the scene or hickup within drone (I use the dev version)
update: I’ve seen that this release has been nuked. The perfect way to go, but how is nzbdrone handling nuked eps?
It doesn’t, its going to cause issues when the 5th episode airs next week, unless you remove and re-add the series (which will clear drone’s history of it). We have some improvements planned for this, but nothing implemented yet.
To add, you could blacklist the release in drone as well, that should fix the issue come next week, even with the same name drone should detect them as different releases (since they were released on different days).
Since the show has changed from Forever (2014) to Forever US, NzbDrone cannot find the episodes… It has the alternative name (Forever US) at the top in grey but seems to be only searching for Forever (2014). Is there any fix on the horizon for this?
Please provide debug logs showing the search and processing of the results. The title is only used to search omgwtfnzbs, other indexers use the tvrage ID.
That one was uploaded with a bad name. Valid names are Forever 2014 or Forever US. Not going to add an alternate name of Forever for one bad release.
Either rename the file manually and drop it in Drone Factory or grab another release. We’ll be making improvements on how we handle these naming conflicts.
