TV Series Title not Parsing Properly in both Daily and Standard Series Type
I am trying to set up a tv series “The Bold and the Beautiful” for my wife, however, there is only one source available (TPB) for download. The person posting uses the following naming convention:
The Bold And The Beautiful - S30 Ep7619 - 2017-06-30
When setting the series to Daily the release is rejected for:
Full season release rejected. All episodes haven’t aired yet.
Existing file meets cutoff: Raw-HD
Quality for release in queue already meets cutoff: WEBDL-480p v1
Quality for existing file on disk is of equal or higher preference: SDTV v1
Episode does not match
When changing the series setting to standard, no results are found. (I am using Jackett indexer with TPB and had to add series category 5050-TV series other to get it to find it as a daily show)
The TVDB reports the episode name correctly as:
First Aired 2017-06-30
Episode Name Ep. #7619
Episode Number 383
This happens with every episode. To download the episodes, I have been using a manual search (daily) which finds one episode with the red exclamation and the above errors. I click the button to add to download queue and the status bar for every episode shows the purple progress bar as if it is recognizing the show as a complete series. I then have to manually import the show and tell sonarr which episode it is.
I am not sure how to handle this. I suppose I could ask the file provider to only use the date in the file name, but it seems to me that sonarr should not be confused by the added information as long as the Episode Name or Episode Number agree with the date when set for a Daily series.
If there is something else I could try, I would appreciate any suggestions that would get this to download automatically. If there is nothing I can do, I thought I should report it for a possible bug fix.
Thank you to everyone who has contributed to such a great product.
We’ll need some more information including debug logs of Sonarr processing those releases.
OS:
((Debug logs)):
No it’s not possible to automate Bold and the Beautiful at this time, the question comes up every now and then, but in order to be able to we’d need to make complicated changes to Sonarr we’re not willing to do yet.
The version is 2.0.0.4851.
I would send the logs but it sounds as if Taloth has seen this before and there is nothing I can do to fix it.
Thanks for the replies!
