Hi,
I have the below dir/file structure for a series called Fleming. It is located in the root or the “Drone Factory” configured path.
For some reason NzbDrone won’t detect and add the files during a scan. I only see “Scanning disk for Fleming” in the logs but nothing happens. I have added many other files and it works ok, just seems these don’t. Is there anything i need to do ?
+--Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb/
| Fleming.S01E01.720p.WEB-DL.DD5.1.H.264-NTb.mkv
| Fleming.S01E02.720p.WEB-DL.DD5.1.H.264-NTb.mkv
| Fleming.S01E03.720p.WEB-DL.DD5.1.H.264-NTb.mkv
| Fleming.S01E04.720p.WEB-DL.DD5.1.H.264-NTb.mkv
Thanks
flo
Looks like it should import just fine, if you enable debug logging it should log why its not importing it.
nothing in the logs I’m afraid, even with debug enabled… below is all I get. No error, info or hints as to why it fails to do anything really. Running NzbDrone Ver. 2.0.0.1269.
[Info] mono: Starting mono --version
[Info] Database: Vacuuming database
[Info] Database: Database Compressed
[Info] RefreshSeriesService: Updating Info for Fleming
[Info] RefreshEpisodeService: Starting episode info refresh for: [276543][Fleming]
[Info] RefreshEpisodeService: Finished episode refresh for series: [276543][Fleming].
[Info] DiskScanService: Scanning disk for Fleming
Check the log files (System -> Logs -> Files), the log table doesn’t show debug messages.
ok, here is the relevant log entries… if i take on of the files from the ‘Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb’ directory and place it in the root of the Drone Factory path then it gets picked up ok… seems to be the directory naming that it doesn’t like.
14-3-24 14:48:39.5|Debug|Parser|Parsing string 'Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb'
14-3-24 14:48:39.5|Debug|Parser|Episode Parsed. flemings01webdlh - S02E64
14-3-24 14:48:39.5|Debug|Parser|Language parsed: English
14-3-24 14:48:39.5|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb
14-3-24 14:48:39.5|Debug|Parser|Quality parsed: WEBDL-720p
14-3-24 14:48:39.5|Debug|Parser|Release Group parsed: NTb
14-3-24 14:48:39.6|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb
14-3-24 14:48:39.6|Debug|DownloadedEpisodesImportService|Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb folder quality: WEBDL-720p
14-3-24 14:48:39.6|Debug|DownloadedEpisodesImportService|Unknown Series Fleming.S01.720p.WEBDL.DD5.1.H.264-NTb
14-3-24 14:48:39.6|Debug|Parser|Parsing string 'Series'
14-3-24 14:48:39.6|Debug|Parser|Unable to parse Series
14-3-24 14:48:39.6|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Series
14-3-24 14:48:39.6|Debug|DownloadedEpisodesImportService|Series folder quality: Unknown
14-3-24 14:48:39.6|Debug|DownloadedEpisodesImportService|Unknown Series Series
14-3-24 14:48:39.7|Debug|Parser|Parsing string 'tv'
14-3-24 14:48:39.7|Debug|Parser|Unable to parse tv
14-3-24 14:48:39.7|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for tv
14-3-24 14:48:39.7|Debug|DownloadedEpisodesImportService|tv folder quality: Unknown
14-3-24 14:48:39.7|Debug|DownloadedEpisodesImportService|Unknown Series tv
14-3-24 14:48:39.7|Debug|DiskScanService|Scanning '/cifs/downloaded' for video files
Yeah, it doesn’t like the folder naming as it is finding season 2 episode 64 from the h.264.
I’ll add it as another test to improve our parsing.
