Trying to understand episode airing times
I was just wondering where ND pulls the episode air time from. I see quite a few shows listed at 6pm and 7pm, like Homeland, Boardwalk Empire, Betrayal etc…
Trakt times are not the same…just a bit confused.
Shedrock
We get the time from trakt, they are timezone adjusted, Homeland is listed at 9pm, which would be EST, since AFAIK all American shows air in EST or EDT (daylight savings time), so in PST, 6pm. Of course if you’re not in PST, it will be adjusted based on the difference from EST.
OMG! I am confused…lol
Well, I think I understand…maybe.
So then, ND is listing the times at 6pm which would be PST. Am I correct on that?
I would think ND would list the same time as trakt, which would be on DST as I am.
Did you fix your timezone after fixing your time? If you’re in in EST (which is what I think you mean instead of DST), then it should show the same time as on trakt.
Yes, I am set to Eastern Time (US & Canada) in Windows.
I just double checked. Three of the four PC’s were set incorrectly after I lost the power today. They were actually set to UTC -08:00 Pacific. Odd, but it is all set up now and ND is just fine.
My apologies for wasting your valuable time.
Shedrock
Try refreshing the series info, might be wrong since your time was so far off.
ok, thanks
