Sonarr version (exact version): 2.0.0.5303
Mono version (if Sonarr is not running on Windows): 5.8.0.127
OS: linux
Debug logs: https://pastebin.com/PMZD924H
It seems as if my frontend is a bit laggy or slow with my setup. I download with SABNZBD (same machine) and let sonarr handle importing cleanup renaming etc. My library is a rclone mounted gdrive folder to where sonarr directly imports.
I made the observation, that not only my “Activity->Queue” is not up to date in realtime (which is what i am used to), it also has a rather huge delay and/or wrong information. This doesn’t bog me much but sometimes it results in failure to do another search when my download has initially failed.
I try to give you an example of my experience so far:
I just downloaded a season of a show. While sabnzbd quickly downloads it AND gets its queue cleaned up nicely by sonarr, the Activity queue in sonarr is stuck. In the logfiles i could find that sonarr seems to be freezing when moving a file. I mean, not freezing it just does not [move] parallel but rather sequentially to other tasks i suppose. This continues for the next episodes too. It imports files, cleans sabnzbds finished downloads but is itself stuck in the activity queue. Sometimes the activity queue shows an error “cannot find the file for importing, folder empty” or something similar. Thats because the folder is long gone and was long before moved already and successfully imported by sonarr. Its like sonarr tricks itself
Now sometimes this results in failure to follow up on failed downloads. Sonarr just won’t look for other releases then, which is the main problem. I don’t have logs for that right now, sorry.
After the whole season is downloaded, and everything cleaned at sabnzbd, sonarr clears in an instant its queue too. I don’t know why it just happened at the end, but it just does. I tried to work through the tasks manually while sabnzbd would still have a full queue, but this did not refresh the activity queue of sonarr too.
This behaviour started when i added the offsite library.
Do you have any ideas on that?
Thanks
