Mono version (if Sonarr is not running on Windows):5.14.0.177
OS: DSM 6.1 - Docker
Description of issue: Trapped (2015) not download and Scene Mapping is added
Trapped new episodies aren´t auto download.
I search it at tracker (HD-SPAIN) and I found:
- hds_Atrapados_2x02_HDTV_1080p_AVC_Dual_DD_5_1_Subs_GrupoHDS-Sharerip.torrent
- hds_Atrapados_2x03_HDTV_1080p_AVC_Dual_DD_5_1_Subs_GrupoHDS-Sharerip.torrent
At Scene Naming doc I can found at line 337:
- 1/18/2019 2:32:00 300754 Atrapados Trapped (2015) Spanish name - Spanish tracker HD-SPAIN Added
When I do manual search at log I found:
19-2-5 11:19:22.6|Info|NzbSearchService|Searching 3 indexers for [Trapped : S02E02]
19-2-5 11:19:22.9|Trace|HttpClient|Req: [GET] http://192.168.1.4:9117/api/v2.0/indexers/newpct/results/torznab/api?t=caps&apikey=(removed)
19-2-5 11:19:22.9|Trace|ConfigService|Using default config value for ‘proxyenabled’ defaultValue:‘False’
19-2-5 11:19:22.9|Debug|Torznab|Downloading Feed http://192.168.1.4:9117/api/v2.0/indexers/hdcity/results/torznab/api?t=tvsearch&cat=5040,5060,5070,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:22.9|Debug|Torznab|Downloading Feed http://192.168.1.4:9117/api/v2.0/indexers/hdspain/results/torznab/api?t=tvsearch&cat=100003,100004,5040,5050,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:22.9|Trace|HttpClient|Req: [GET] http://192.168.1.4:9117/api/v2.0/indexers/hdcity/results/torznab/api?t=tvsearch&cat=5040,5060,5070,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:22.9|Trace|RateLimitService|Rate Limit triggered, delaying ‘192.168.1.4’ for 1.999 sec
19-2-5 11:19:23.4|Trace|HttpClient|Res: [GET] http://192.168.1.4:9117/api/v2.0/indexers/newpct/results/torznab/api?t=caps&apikey=(removed) 200.OK (518 ms)
19-2-5 11:19:23.4|Debug|Torznab|Downloading Feed http://192.168.1.4:9117/api/v2.0/indexers/newpct/results/torznab/api?t=tvsearch&cat=5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:23.4|Trace|RateLimitService|Rate Limit triggered, delaying ‘192.168.1.4’ for 3.481 sec
19-2-5 11:19:24.9|Trace|HttpClient|Req: [GET] http://192.168.1.4:9117/api/v2.0/indexers/hdspain/results/torznab/api?t=tvsearch&cat=100003,100004,5040,5050,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:24.9|Trace|ConfigService|Using default config value for ‘proxyenabled’ defaultValue:‘False’
19-2-5 11:19:26.0|Trace|HttpClient|Res: [GET] http://192.168.1.4:9117/api/v2.0/indexers/hdcity/results/torznab/api?t=tvsearch&cat=5040,5060,5070,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2: 200.OK (3088 ms)
19-2-5 11:19:26.3|Trace|HttpClient|Res: [GET] http://192.168.1.4:9117/api/v2.0/indexers/hdspain/results/torznab/api?t=tvsearch&cat=100003,100004,5040,5050,5080&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2: 200.OK (1385 ms)
19-2-5 11:19:26.9|Trace|HttpClient|Req: [GET] http://192.168.1.4:9117/api/v2.0/indexers/newpct/results/torznab/api?t=tvsearch&cat=5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2
19-2-5 11:19:26.9|Trace|ConfigService|Using default config value for ‘proxyenabled’ defaultValue:‘False’
19-2-5 11:19:28.3|Trace|HttpClient|Res: [GET] http://192.168.1.4:9117/api/v2.0/indexers/newpct/results/torznab/api?t=tvsearch&cat=5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Trapped&season=2&ep=2: 200.OK (1430 ms)
19-2-5 11:19:28.3|Debug|NzbSearchService|Total of 0 reports were found for [Trapped : S02E02] from 3 indexers
