Hi,
I’ve been using Sonarr for quite a while now and transmission has worked really well since the initial support in the torrents branch. But I’ve recently moved SAB/Transmission off on to a different machine than where Sonarr is running, and progress bars are not always working, and as a result the completed downloads don’t get imported at the end. I have to manually move the file from the normal download folder to the factory folder and wait for that (or force the task to run earlier).
Other than the progress bars, everything in transmission from Sonarr’s perspective appears to be fine. The logs show no errors either.
I’m using transmission v2.84 from the Archlinux repos and sonarr-develop v2.0.0.3037.
