Transmission - not downloading anything
Download Clients is enabled but nothing is getting dowloaded. what should i do?
Did you test the connection to transmission?
I get “testing transmission completed”.
Do you have a torrent indexer enabled?
Yes. I did add eztv. what now? should i open transmission software and wait for sonarr to downaload?
It should, if there are new episodes on the RSS for that indexer which are wanted by your sonarr install. See How does sonarr find episodes.
If you want to actively start downloading older episodes, use the magnifying glass icon on the entire series, a season, or an individual episode to search automatically for an episode that matches your quality settings, or use the manual search icon next to it (only on individual episodes) to manually search&select an episode for downloading.
Manual search is also useful to confirm your sonarr setup. E.g. if you see the episode you want on your indexers website, but sonarr’s automatic search is not grabbing that episode.
In that case, a manual search will show you why it was not grabbed for a number of reasons. Size, quality, blocked words in the release name, …
Hope this helps a little.
