Hi,
I have added eztv and transmission. Still nothing get downloaded. What do i miss? Why is this soooooo difficult?
Have you read the FAQ?
Yes!!! Thats why i have the indexer and download client ready. but nothing gets downloaded. what more do i need to install`
A series needs to be added and you need to search for it (as explained in the FAQ), unless the episode was recently posted.
I have done that. like i told in my first post. nothing gets downloaded!
We’ll need to see debug logs of an RSS sync that contains an episode you want in order to troubleshoot.
You can also try a manual search to see if results are showing up (you’ll need to use an indexer that supports search as EZTV does not).
It seems to work when i change the indexer to rarbg. Will the next episode download automatically? do i need to have transmission open?
It should download automatically if the series and episode are both monitored and no other things reject it (now allowed terms, size, etc). Yes, transmission will need to be open.
