Sonarr version (exact version): 2.0.0.5054 - 04 Nov 2017 Mono version (if Sonarr is not running on Windows): 4.0.0 OS: MacOS High Sierra Version 10.13.1 Debug logs: https://cl.ly/nmvb/Report.rtf (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue: For some time now Transmission is not available in Sonarr … and when i try to download manualy a torrent it says is disabled …
The fact that it reports the error when manually grabbing a release is a bug that will be fixed in the next release, but the underlying issue is that Sonarr failed to talk to Transmission at some point recently and disabled it temporarily. You can go to Settings: Download Clients and test Transmission to clear the error immediately otherwise it will clear on it’s own.
It’s still very stubborn … takes a while to spin the loading weel and the result is always the same: “failed”.
maybe the next update will solve my problem …
What do the logs show when you test it? Your previous log files showed an issue with looking up the hostname in DNS,which may have been set to hostname.
Please post the text file as-is not as an RTf file.
Looks like you’re running mono 4.0, which is quite old, upgrading mono would be good regardless, upgrading to the latest version should be safe on your version of macOS
hmm i did restart Sonarr, i tryed also shut down Sonarr, restart OSX, remove Sonarr and put the new version in Application … it still looks like Mono 4…
Maybe this is the problem, that its stuck on Mono 4 ? Or maybe the OSX version is only on Mono 4 ?
I dont want to reinstall all of the settings and put again all the tv show … but maybe a clean install will solve this pesky issue?
