Torrents sent to deluge paused after completed
I’ve been using nzbdrone 2.0.0.2060 (torrents branch) and deluge 1.3.7 headless server. Prior to taking the three most recent updates, torrents that were sent to deluge and completed, were effectively removed from the queue using deluge’s label “Stop seed at ratio = 0” option (public trackers).
It would seem now that completed torrents are put into the “paused” state and the label option mentioned above has no effect.
I was wondering if indeed drone changes the torrent state to paused and is there an option to remove torrents from the queue upon completion?
Thanks
Stop seed at ratio means Deluge puts it in pause.
Since recently we forcibly set “remove at ratio” to false since having it on true could prevent drone from importing, because that could lead to the torrent being removed from the deluge api before drone had a chance to import.
On another note. I’m rather antagonistic about not seeding till at least 1:1 ratio. I know you want to avoid seeding on public trackers, but that’s not really an excuse imo.
