Torrentleech CAPTCHA msg
Sonarr version (exact version): 2.0.0.4689
Mono Version 4.8.0
OS: Ubuntu
Suddenly trying to connect to torrentleech via sonarr gives the error Site protected by CloudFlare CAPTCHA. Valid CAPTCHA token required
Is there anything that can be done about this?
No, if you’re using a VPN try a different endpoint as the IP may be blocked.
I am not using a vpn, sonnar is running on a dedicated server from a hosting company.
It’s possible TL temporarily increased their CloudFlare security level and it will work again, but it’s also possible they have dispatched for a range of IPs.
Sonarr can’t do anything to work around it, but maybe the TL admins can help you out.
Thanks I have posted on their forum asking for any suggestions.
