Sonarr version (exact version): 2.0.0.5163 Mono version (if Sonarr is not running on Windows): 5.12.0.226 OS: Docker Image linuxserver/sonarr Description of issue:
The TorrentBlackhole edit dialog shows the static message “Magnet links are not supported.”. But how exactly are magnet links not supported? There is the switch “Save Magnet Files” in the same dialog and I can confirm that it works fine with the TorrentBlackhole.
Your definition of “Works fine with the TorrentBlackhole” isn’t entirely true… All the black hole is is a dump folder… MY client (RTorrent) does not support magnet files… it just does nothing with them…
So i have to run a small VBS file to convert them in to torrent files.
