Sonarr version (exact version): 2.0.0.4949
OS: Windows 10 Creator’s Update
((Debug logs)): https://pastebin.com/R6dDxZ6V
Description of issue: Using hardlinks, upgrades or propers can’t be moved/processed until the lower quality torrent stops seeding (pause/completed/etc… due to file lock on the original hardlinked file). I found a similar issue from a few years ago, but it seems that the discussion was closed without any progress - Drone gives error when trying to upgrade hardlinked file. It seems that temporarily pausing the torrent in the client releases the lock, and I think that Sonarr has enough information to find the specific torrent in the client that needs to be paused (using save_path from the client, along w/ the location of the hardlink to match against). Alternatively, a pause could be issued for ALL torrents (simplifies things a bit) but that seems like overkill. I downloaded the source and was able to build/run Sonarr locally, but I’ve had a very hard time trying to replicate the torrent save/upgrade process in order to add the pausing capabilities. If anyone is familiar w/ this on the dev side it’d be a huge help, or if anyone has already looked into this issue and has possible solutions I’d love to hear them as well!
