Did title sorting on the series page (table view) change in one of the latest updates? Title sort has always used the second word for shows that start with “The” but now I’m seeing the same behavior with shows that start with “A”. Was that intended? There are a number of shows that this works fine on but shows like “A To Z” are now sorted down in the T’s which doesn’t make any sense.
@markus101
If the sort is omitting articles (the, a, an, …), then a show called “A to Z” will be sorted as “to Z”, I guess?
That is correct and unless I’m off my rocker the behavior changed in one of the recent updates. I have the following shows that no longer sort at the top under “A”.
- A Moody Christmas
- A To Z
- A Touch of Cloth
Not a recent change, this changed a while ago, a/the/an are ignored when sorting.
Damned if you do, damned if you don’t.
