Sonarr version 3.0.6.1342:
Mono version 6.12.0.122:
OS Ubuntu 20.04:
There are 2 different roots titles, 1 from 2020 and one from 1977, I can’t add one if the other one is in my system as it gives the slug conflict. Please could you make a change in skyhook in order to override the generated slug?:
This should be fixed on TVDB not skyhook.
TVDB rules are the second series should have the year in its name (and thus in the slug)
You will likely need a ticket and then wait for them to eventually fix it
I saw this discussion where it happened:
Those were two different names technically- TVDB just doesn’t treat &/and as the same series
So I have to wait for TVDB to fix? There is no way of adding an exception?
