There’s a new show on HBO Called “Divorce”. When you try and search to add it in Sonarr, it doesn’t find it, when you search by tvdb id, i find it, when i add it, it seems like it adds it to the bottom of the alphabetic list, also, it won’t find it when i attempt to download, even though its available, i can manually import which is does say “unknown series”, but i can tell it which one to import as. It almost seems like there is a character in from of “Divorce (2016)” that it’s adding for some reason. The TVDB id is: 314599. Let me know what you think. Thanks in advance.
Unrelated to the topic you posted in, but this sounds like something a moderator on the TVDB needs to fix (opening a thread on their forums), if it hasn’t been resolved already.
This still isn’t fixed yet, any eta on there end ?
Edit you need to be in 2016 for it to show
