I’m having quite a few problems with the new timezone correction feature: talk shows (or any show with a date in the title, for that matter) are not being recognized correctly.
Example: the Daily Show. Last Thursday (07/25/2013) episode aired (as usual) at 11pm eastern; I’m on GMT+1 (+7h from EST) so it’s (correctly) being displayed as having been broadcast on Friday (07/26/2013) at 6am.
Problem is, there is no Friday episode; episodes are Monday through Thursday. So when the program tries to look for the 2013-07-26 episode, it doesn’t find it. Moreover, Tuesday episodes are recognized as Monday episodes, Wednesday episodes as Tuesday episodes, and so on and so forth.
Is there anything that can be done?
The actual searching and mapping NzbDrone does is based off of the air date in the time zone the episode aired, not your time zone. The one thing that might be an issue right now is the display in the UI for the episode details modal, since I believe it is showing the time zone adjusted time, not the aired time zone. Is that what you’re seeing?
I have fixed the air date display in the modal, but I can’t reproduce the issue with the searching (even after changing my timezone to GMT+1. If you’re able please upload your database and PM me a link to download it, I want to verify something in the DB.
Tried starting from scratch but no dice, same results.
Contents of the ProgramData directory (doesn’t contain any sensitive information): http://db.tt/IDkCToAo
Found the issue, I didn’t see it when I tried to replicate because I didn’t restart my app. Have a fix for it, will get it out soon and you’ll need to refresh/wait for the automatic refresh (happens every 12 hours).
