Hi,
I’ve got a timezone issue with the Calendar. Currently all shows are showing as airing an hour earlier than they are in fact airing. The time was set wrong on the server (for some reason it hadn’t caught up with the move from daylight savings time to standard time), which accounted for the error. I’ve changed the time on the server, but the times in the calendar haven’t changed. I’ve restarted NzbDrone, but it has not had any effect. Can you advise how to force the change, so the calendar airtimes are shown correctly?
Thanks
Matt
