I have Sonar running for a long time but it seems like it has troubles lately. I have a lot of entries that look like this:
Request Failed. POST /api/series: The underlying connection was closed: The connection was closed unexpectedly.
System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly.
at System.Net.HttpWebRequest.GetResponse()
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 76
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:line 60
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 70
at NzbDrone.Common.Http.HttpClient.Get[T](HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 198
at NzbDrone.Core.MetadataSource.SkyHook.SkyHookProxy.GetSeriesInfo(Int32 tvdbSeriesId) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MetadataSource\SkyHook\SkyHookProxy.cs:line 40
at NzbDrone.Core.Tv.AddSeriesService.AddSkyhookData(Series newSeries) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Tv\AddSeriesService.cs:line 77
at NzbDrone.Core.Tv.AddSeriesService.AddSeries(Series newSeries) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Tv\AddSeriesService.cs:line 46
at NzbDrone.Api.Series.SeriesModule.AddSeries(SeriesResource seriesResource) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Api\Series\SeriesModule.cs:line 119
at NzbDrone.Api.REST.RestModule1.<set_CreateResource>b__41_0(Object options) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Api\REST\RestModule.cs:line 155 at CallSite.Target(Closure , CallSite , Func
2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.b__3(Object parameters, CancellationToken context)
I am running on Windows 10 with the latest version. Has anyone seen this error before?
Stephan
