Sonarr version (exact version): Don’t know where to find this. D/Ld on Jan 12 2018
Mono version (if Sonarr is not running on Windows): Windows
OS: Windows 7
Debug logs: Don’t know what this means
Description of issue: Could someone pls get me over this hump? When I enter Sonarr, I get “you must be new here, add a series”. OK. I find one, but the “Select Path” is greyed out. I can’t enter path. I can enter “enter different path”, but nothing seems to happen when I do. I have SAB working - I can specify an NZB and it will decode and unpack in the path I specified.
I went to Beginners guide but the link is broken. I searched other similar forum issues, but they are start AFTER you enter the path. I cannot enter any path.
This “path” problem seems to be a common confusion with Sonarr, and it seems to have something to do with the “default path” when Sonarr is installed. Mine defaulted to C:\Program Data, I had no other choice. I read somewhere NOT to put it in there, but how else can you specify where it goes? Would that fix the problem. Very confusing, thank you for your advice.
