Tests appear to fail
Sonarr version (exact version): 2.0.0.4389
Mono version (if Sonarr is not running on Windows): 4.0.0 ((detached/d136b79 Mon Apr 13 14:40:59 EDT 2015)
OS: OS X 10.12.6
((Debug logs)):
newznab: https://hastebin.com/lunezodihe.sql
omgwtfnzbs: https://hastebin.com/arayadipun.rb
Description of issue: When I hit the test button on for any of my indexers the return message is test failed. The link I’ve attached has data for Newznab. Overall, except for the one show I mentioned in a new topic I created a few minutes ago, Sonarr seems to be working for other shows. So it’s not clear which of these failures are real and which aren’t. I think if they were all real Sonarr wouldn’t be downloading stuff at all.
Regardless, I’ve triple checked the entries for each indexer and confirmed I can manually log into the indexers and search for stuff. So I can use the test button to diagnose anything because I can’t tell if it’s telling the truth or not.
Both logs show a successful test, besides failed what does it say?
