Sonarr version (exact version): 3.0.0.230 Mono version (if Sonarr is not running on Windows): 5.14.0.177 OS: Debian 9 Debug logs: - (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here. Post in .txt not .doc, .rtf or some other formatted document) Description of issue: System > Updates > List not clear
When going to System > Updates it isn’t clear what has been updated/fixed in the new release because they all look the same or has every update the same fix ?
with in the future you mean in one of the upcoming releases or the final ?
Because i always automatic check what’s updated after a update and want to test if it works or broke something else.
But now it is kinda impossible to see what has been changed.
