System update-"connection to backend lost"
Hi
I am new to this forum so please be patient.
I have been running nzbdrone for a few weeks (on mac os) and no problems with previous updates.
Now updating from 2.0.0.1861 to 2.0.0.2046 receive message “connection to backend lost” This has happened a number of times.
This is a copy of my logs during update.
GlobalExceptionHandlers SignalR Heartbeat error. 8:04am
Database Database Compressed 8:04am
Database Vacuuming database 8:04am
HousekeepingService Running housecleaning tasks 8:04am
SceneMappingService Updating Scene mappings 8:04am
InstallUpdateService NzbDrone will restart shortly. 8:03am
InstallUpdateService Starting update client /var/folders/0v/57qbbx1129q5m_mx3wvxhgsr0000gn/T/nzbdrone_update/NzbDrone.Update.exe 8:03am
InstallUpdateService Preparing client 8:03am
BackupService Starting Backup 8:03am
InstallUpdateService Update package extracted successfully 8:03am
InstallUpdateService Extracting Update package 8:03am
InstallUpdateService Update package verified successfully 8:03am
InstallUpdateService Verifying update package 8:03am
InstallUpdateService Downloading update 2.0.0.2046 8:03am
InstallUpdateService Deleting old update files 8:03am
RssSyncService RSS Sync Completed. Reports found: 299, Reports grabbed: 0 7:54am
DownloadDecisionMaker Processing 299 reports 7:54am
RssSyncService Starting RSS Sync 7:54am
Database Database Compressed 7:48am
Database Vacuuming database 7:48am
RssSyncService RSS Sync Completed. Reports found: 299, Reports grabbed: 0 7:39am
DownloadDecisionMaker Processing 299 reports 7:39am
Database Database Compressed 7:39am
Database Vacuuming database 7:39am
drone will display that message if its unable to connect to the backend server for 3 minutes or longer, based on your logs this wasn’t the case during the update window. When exactly did you see this message?
I clicked on the install button of the update and it went through all the actions in the log.
Black dots were pulsating across the system sections and after a few minutes the screen went grey and the message appeared.
I then had to restart drone.
Did the update install successfully?
How do you have drone running? plist file? If so, it sounds like you need to update the plist (possibly), see: http://forums.nzbdrone.com/t/issues-with-update-osx/942/10 for more info
The update.css file in drone file is dated 26th Aug 2014. That is when I first tried to update to 2.0.0.2046.
I have drone running from “Lingon X”. I see from the forum address you left Lingon X does not always work. I will try running direct from the terminal. I was running from terminal when I updated to 2.0.01861 and update worked ok.
