Hi everyone,
I’m trying to dive into Sonarr and replace my existing Sickbeard with it on a Synology DS413j with last DSM 5 update.
I tried 3 things and everytime I stopped all un needed processes like Sickbeard, CouchPotato etc… to be sure that nothing interfers with Sonarr.
For every try, I was not able to have the service running: Mono was running but not NZBDrone.
1/ Install from Synocom. both Mono + NZBDrone (mono first)
2/ Same as 1 + manual update to this version: https://github.com/SynoCommunity/spksrc/issues/671#issuecomment-53181568 (using 88f6281 build)
3/ Manual install from the github updated version
Nothing seems to make it work: I cannot start the service on my Synology. There is no logs at all for NZBDrone and Mono is running correctly…
About the architecture, the 413j is 88f6282 but i’m using the 88f6281 version: is it OK ?
Thanks for the help!
