Sonarr version (exact version): 20210717-19 (3.0.5.1144)
Mono version (if Sonarr is not running on Windows): 5.21.1.34-17
OS: Synology / Linux
I installed Sonarr on my Synology NAS using the Synology package centre (successfully - could get the consoles etc, didn’t test functionality), then had a brain fade and took a backup of my Sonarr setup on Windows (using the system>Backup option), and restored it to my Synology install. The Synology install then started complaining ‘is not a valid *nix path. paths must start with / Parameter name: path’.
I then went into packages and uninstalled both the Sonarr package, and the Mono package and reinstalled.
When I go back into the the console, nothing comes up except for the ‘is not a valid *nix path. paths must start with / Parameter name: path’ message. I can’t do anything, make any changes, etc. It seems the uninstall is leaving something behind but not sure what or how to get rid of it so I can start from a blank canvas. Any ideas how I can do a complete cleanup and start fresh?
