Synology & Docker permission troubles
**Sonarr version 2.0.0.5228
**Mono version 5.14.0.177
OS: Synology DS918
New to Synology and Sonarr, after following the set up I keep getting this error
Import failed, path does not exist or is not accessible by Sonarr: /downloads/Tv Show Name
I have tried setting up Remote Path Mappings
Host 192.168.1.79 ( the IP of the NAS
Remote Path
/volume1/downloads
Local Path
/downloads/
Sonarr correctly finds episodes and sends them to SABnzbd, which is running via docker on the Synology NAS. SABnzbd downloads the episode, but Sonarr does not import it. I always get errors as described above.
Open for any advice on how to fix this.
Sab seems to be dropping the files into nas19\downloads\complete ( when looking from my PC)
Close
if theyre both in docker (and on the same host) then you should just need a common volume/mount path in each docker config
presumably sab is set to save to /downloads so it must have a volume setup for /downloads in its docker config
did you setup the same /downloads volume in the docker config for sonarr as well?
Fixed :slight_smile: haha
