Sonarr version (exact version): 2.0.0.5153
Mono version (if Sonarr is not running on Windows): 5.10.0.160
OS: DSM 6.1.5-15254 Update 1
Hi everybody!
It seems that I can’t make sonarr to import downloaded files.
I am getting the infamous error by DownloadedEpisodesImportService:
Import failed, path does not exist or is not accessible by Sonarr: /volume1/downloads/complete/sonarr/The.Show.S01.E01.avi
I am running sonarr in docker on a Synology NAS. In docker, I mounted the paths as written in this guide, with the excpection of naming the mount path to the folder for my tv shows /TV Shows
instead of /tv
for reasons of consistency.
I have configured the environment variables PUID and PUIG according to above mentioned guide as well, and the user and group I have defined definitely have permissions for all the folders in question.
Sonarr correctly finds episodes and sends them to SABnzbd, which is not running via docker but as an app directly on the Synology NAS by the way. SABnzbd downloads the episode, but Sonarr does not import it. I always get errors as described above.
However, when I try to manually add an episode in Sonarr by navigating to Wanted -> Manual Import, everything works fine. Obviously Sonarr is able to read and write the /downloads and /TV Shows folders after all!
Does anybody have an idea how to get this to work?
Mind that I have already tried to set Remote Path Mappings in Settings -> Download Client already. This did not help unfortunately.
I’d really appreciate some help!
