OS: SYNOLOGY
Debug logs: https://drive.google.com/file/d/1JnuAVleBK6v0D8DtNkTPZVWdwYbVkdjE/view?usp=drivesdk
Description of issue: Can’t find episodes but radarr with same setting is working fine
Im using planet as indexer and Sabnzbd everything in docker, folders are setup correctly permissions are fine
|Warn|Newznab|nzbplanet.net https://api.nzbplanet.net/api?t=tvsearch&cat=5000,5030,5040,5045&extended=1&apikey=(removed)&offset=0&limit=100 DNS Name Resolution Failure: ‘api.nzbplanet.net’
