Suffix or Script
Hi team,
I was wondering if we could get a suffix to the downloads started by NzbDrone or a SAB script. Problem is, sometimes the name of the video file for a download is gibberish (even though it may be inside a properly-named folder). SB’s plugin gets it around these, as it smartens SB up to know what download corresponds with what episode. NzbDrone just fails to scrape them.
I would post this on Trello, but I don’t appear to have permission, or something.
can you post a full path of a file that isn’t being imported by nzbdrone?
NzbDrone uses the folder name to determine the series title, but the filename to determine the season and episode numbers (since its possible for a folder to contain more than 1 file).
For example:
C:\\Test\\Unsorted\\The.Big.Bang.Theory.S01E01.720p.HDTV\\tbbt101.avi
should properly get picked up as The Big Bang Theory S01E01
But as kayone said, please submit the path.
I don’t have one handy, but it would be something like:
E:\Downloads\tv\The.Big.Bang.Theory.S01E01.720p.HDTV\ajifajjjeaeaeqwer_eppj.avi
Where the file name is just complete gibberish. I think having a script run on download like Sickbeard or a forced identifier suffix like CouchPotato might fix this.
I’m pretty sure we can fix this on our side without needing a script.
I created a card for it on trello https://trello.com/c/1LFo1Z2o
Ah. Well if you can do that, great.
