Special searching isnât the greatest due to the various formats that are used, usually just the episode title, but sometimes S00Eyy or SxxEyy.
The file size rejection happens there because Sonarr doesnât have a S05E00 in its list of episodes, really it should probably say the episode is unknown.
Thats because it doesnât match the one you searched for, Sonarr has no way of knowing S00E02 is the same as S05E00.
Sonarr finds a title match after it tries via SxxEyy matching, which exists for the other releases, but not the SD one.
Thanks for all those explanations @markus101
I forgot to actually say what really bugged me. I totally understand the algos behind all that. But if sonarr find a release, and the one that i actually want (the first one), then i would like to have the possibility to download it from sonarr.
But the âdownloadâ button is missing from the 2 first releases.
I understand it comes from the fact that the name does not match the episode ânumberâ. I guess it found it thanks to the episode name. But then it should let me download it, even if i am the one to have to rename it after.
My point: if a search result is shown, i should always be able to trigger its download.
