After NzbDrone updated itself it seems to have gone wrong somewhere.
I’m not monitoring NzbDrone 24/7 so I don’t know after which version the troubles began, but I guess its Ver. 2.0.0.419.
1 - I noticed I couldn’t reach the webif anymore. Went to the system by Remote Desktop. Service not started. Restarting it gave the following error: The NzbDrone-service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other service or programs
2 - Started NzbDrone.Console.exe - this one keeps running (NzbDrone.Console.exe*32 stays in taskmanager), but spits out the following error during startup: netsh.exe: Url reservation add failed, Error: 183 Cannot create a file when that file already exists. Result: Webif doesn’t work.
3 - Started NzbDrone.exe. Result:
4 - Grrr.
5 - Unpacked NzbDrone.develop.2.0.0.501.zip to desktop. Ran NzbDrone.exe - worked flawless. Must be a problem with 419… wait till new master version
6 - Noticed a new master version (516), extracted it in 419 folder (overwrite, and also as fresh new folder): Result: Same as point 2 and 3 … Huh?
7 - Ran v501 again (still extracted in a folder on the desktop) no problem … hmmmm
8 - Ran update on v501 (through webif: System -> Check for update) … webif didn’t react anymore, killed nzbdrone… started it again: Error 2 and 3!!
9 - Unpacked NzbDrone.develop.2.0.0.529.zip, ran NzbDrone.exe - works flawless! Update didn’t have any effect, since there is no new version at the moment of writing.
Questions:
What do the errors mean?
It seems to be related to update problems, correct?
