Status for downloaded items but not sorted
Sonarr version (exact version): 3.0.1.418
OS: Win10
Hi guys,
Im using sonarr on a laptop win10, and the torrent client in another sever (unix), without any link except ftp.
I’don’t want sonarr to download automatically items from the seedbox so i uncheck ‘Completed Download Handling’. But in this way my items first dowload successfully on the seedbox but the statut reset to ‘missing’…
Then i refesh the calendar and it’s start to downloading statut again :frowning:
Is there a way to not download (in torrent client) an item which has already been downloaded (torrent client) even if it’s not imported and sorted by sonarr ?
Btw is it normal in calendar view when i click on ‘search for missing’ it try to download even the unmonitored items ? o.O
With Completed Download Handling disabled Sonarr will ignore all complete downloads in your client, if you want Sonarr to know they’re still there then you could enable it and ensure Sonarr can’t import (which it wouldn’t be able to from a remote seedbox unless you mapped things so it could).
Until a file exists on disk in the series folder it’ll be considered missing.
Yes, it searches for everything missing included unmonitored if those are visible.
