slipx
August 3, 2013, 3:44am
1
I’m getting the following error when using the SSL version of my indexer.
FetchFeedService NZBSA SSL server is currently unavailable.https://ssl.nzbsa.co.za/api?t=tvsearch&cat=5030,5040&apikey=xxxxxxxxx&limit=100&q=xxxxxxxx The operation has timed out.
If I copy and paste this into my browser it returns search results. It also works in SickBeard. If I switch over to the HTTP URL it works fine.
I suspect it might be an issue I saw before with how the server and NzbDrone try to build the SSL connection. Can you try installing. Net 4.5 and see if that solves it?http://www.microsoft.com/en-ca/download/details.aspx?id=30653
If you’re still having issues and could spare an invite I can dig into the issue further, or if they have an IRC channel I could speak to them about getting a test account.
slipx
August 4, 2013, 5:39am
3
Thanks installing .Net 4.5 fixed the problem
kgnw
August 6, 2013, 8:00pm
4
Having the same problem on an xp box. Can’t install .Net 4.5 on that. Will there be a solution when the linux version is ready?
kayone
August 6, 2013, 8:54pm
5
